Home › Forums › Electronics Restoration › 1954 Marconi AM Radio Motorboating
Viewing 5 posts - 1 through 5 (of 5 total)
  • #6628
    I am fixing up a 1954 AM Marconi radio. I recap it and it runs good once tuned to an AM station however I get motorboating between the stations. Any ideas? I check the tubes and shields but all looks good.
    #6649
    Peter Heembrock
    Sounds like it could be an AGC related issue…have you checked all resistor values as well?
    Has the set been re-aligned?
    #6653
    Google ”Motorboating” What it is, and why.. The article might give you some helpful information.
    #6654
    Peter Heembrock
    See attached pdf article from may back…
    #6665
    Also make sure that your coupling cap replacements aren’t too high (eg 0.1 uF instead of 0.01 uF).
