Home › Forums › For Sale / Wanted › WTB 12 inch speaker 815 ohms
  • #7723
    I have a Westinghouse model 1029 radio and it needs a 12 inch speaker.
    The field coil of the factory speaker one states 815 ohms with a voice coil of 5 ohms’
    If you have something that will work please email me. Thanks,, Dan Walker
    #7724
    Dan;
    Nice radio from the late 30’s.
    I guess the first question is: has one of the 2 coils on the speaker failed. If the field coil which is acting as a power supply choke is OK then there is no reason for you not to re-use it ( perhaps temporarily – disconnecting the speaker voice coil leads ) and connect a 4 ohm speaker to the output transformer. If you are concerned about the 4 ohms instead of 5, put a 1 ohm , 10 watt resistor in series with it to bring the speaker load to 5 ohms.
    If the field coil is fried then you can replace it with a fixed inductor. Hammond , for one makes them. You will need one that can handle at least 50 to 60 milliamps , as the 6L6 ouput tube can use most of that current and there are a couple of other tubes fed thru that choke.
    Instead of the replacement choke you can use a power resistor of the same value , 815 ohms. It should make the dc voltage very close but you will lose the filtering effect of the choke.
    This is just a couple of suggestions for temporary fixes, that will put your radio back on the air until you get the proper speaker.
    Hope this helps. Regards John G.
    #7725
    Thanks John.. the field coil is fine ,but the problem is in the voice coil. It was rubbing and I find that the coil can’t be repaired. I do know that I can use a PM speaker with the field coil that I now have but I would like to have an original speaker instead of using the old field coil with a PM speaker inside the cabinet.
    There is not anyone in Calgary that repairs speakers, so if I can find one it would make it more original.
    This is the third one of these radio I have had. gave the first one to my daughter and sold the second one
