https://www.radiomuseum.org/r/phonolacan_6525_s.html
I wanted to know how to proceed with what I believe is a wire wound resistor. I think it is supposed to be 500,000 ohms.
It tests at .554 megs when measured from the blue arrows but only .4 ohms when measured from the yellow arrows. I removed the brown paper that is at both ends to test it. I then unsoldered one end, tested again and got .4 ohms.
Is this a wire wound resistor and if so, how do you properly test them and if a replacement is need, what is it replaced with as far as wattage etc.
This topic was modified 5 years, 2 months ago by
. Reason: Grammar correction
