Home › Forums › For Sale / Wanted › Wanted: Rogers 6H7S triode/pentode
  • #11095
    Bruce Winter
    Looking for this seemingly rare, Rogers manufactured tube. There is a substitute, which means changing the tube socket, but would like to keep it original if possible. I’m located in the lower mainland of BC.
    Thanks,
    Bruce
    #11096
    Checked all my tube guys out east without luck. Some don’t even have a listing for it. Found this substitution schematic which you probably already have.
    http://pacifictv.ca/schematics/rogers6h7msubdata.pdf
    http://www.tubebazar.com/services.html
    • This reply was modified 7 years, 8 months ago by garykuster. Reason: new info added
    #11114
    Bruce
    I would suggest that if you have the room inside the radio, make an adapter socket with the 7 pin male and an octal socket. You can then use the radio with the substitute tube until you find an original. This keeps the radio as you want it but allows you to use it or even just to show it works.
    Good Luck with it.
    #11120
    Bruce Winter
    Gary, thanks for doing a tube search and the references.
    John, that is an interesting idea and may have to go that route. Will keeping looking for now.
    Appreciate the feedback,
    Bruce
    #11156
    Still need this? I will search my tubes if you do. I have over 2000 unorganized tubes.
    James
    AKA Aladdinsane
    #11177
    Greg Bilodeau
    I have been collecting and repairing old radios for more than 30 years now. I have north of 30K tubes and have only ever seen this tube once in all of those years and tubes. It is scarce and the only one I found was no good. You might be better off to do the recommended mod to the set and use the subs.
    Good luck in your search.
    Gregb
    #11187
    Bruce Winter
    Hello James – yes, still looking for one to turn up. I would appreciate if you would have a look in your stock. Thanks.
    Bruce
    #11194
    Will do. Might take a while.
