Home › Forums › For Sale / Wanted › WANTED AUDIO OUTPUT TRANSFORMER 2.5 K – 8 OHM
  • #17086
    rudedaddy
    I am working on a Electrohome ” Cosmic ” 5 tube radio that the audio transformer is missing . The output tube is a 50B5 . So what is needed is a small 2.5 k ohm to 8 ohm .
    #17087
    If you want to test your radio a 120 volt to 6.3 volt small power transformer will be close enough, impedance wise to work.
    It is actually about 2900 to 8 .
    a 6.3 volt with a 115 volt primary is even better at 2660 to 8.
    #17173
    rudedaddy
    Thanks for your help …. I found one in a scrap chassis …. got the radio all restored now ….
