Home › Forums › Radio Parts Wish List › Tube 12B6 or 12Q7
  • #17810
    Looking for a 12B6 for my Deforest W05/41 Ch= 10DA517 or a 12Q7 can work if I modify the wiring.
    https://www.radiomuseum.org/r/deforest_w0541_ch_10da517.html
    #17811
    Will look tomorrow, i may have.
    #17822
    I have a 12q7gt that tests around 70 percent on my tc2 heathkit tester.
    #17833
    Les,
    I am puzzled why you would need to rewire the socket to go from a 12B6 to a 12Q7.
    They have the same basing diagram.
    Is the 12B6 one of those special Rogers tubes ?
    #17834
    Hi John. I’m basing this on advise on the radiomuseum site where it says “Particular Rogers type. In a GE list of equivalents it should be replaceable by 12Q7, but that is not correct, since base and wiring must be changed. ” Source: https://www.radiomuseum.org/tubes/tube_12b6.html
    #17835
    Les i sent you a message back.
