Home › Forums › Electronics Restoration › Troubleshooting Help
  • #8151
    What would cause a radio – after it’s been re-capped and the tubes checked out – to work for several minutes then fade out, sometimes crackling and the volume changing on it’s own. I’ve got a couple of radios doing this now: CGE 601C and Musicaire MD249. I’m not sure where to start looking for the issue.
    #8155
    Les;
    My first guess would be one of the large value resistors in the AVC circuit, including the volume control itself. Perhaps you can supply an alternate resistive divider by removing the center lead of the control ( the wiper ) and using a couple of fixed resistors to give you an appropriate audio level.
    Good luck with it.
    #8174
    Thanks for the advice John. I found a bad resistor in the AVC circuit and all is well.
