Home › Forums › Electronics Restoration › Thorcraft B71 resistor
- This topic has 2 replies, 2 voices, and was last updated 9 years, 1 month ago by
September 13, 2017 at 8:24 pm #9526
Forum ParticipantHello forum
Unfortunately, I bought this radio without doing much research on it. Good thing it was cheap. A standard 2 prong AC cord was on it so I thought it was a 115v AC unit. Well….so did the previous owner as it was plugged into wall outlet at some point. Turns out it’s a 32vdc unit. Thorcraft did not publish schematics apparently so it’s a guess as to value of the burnt power resistor in the photo linked below. Or perhaps someone owns this radio and can assist. One end of the resistor is fed the +32vdc from the switch and the other heads to an electrolytic cap lug of 20mfd. That in turn has leads that go to pin 4 of both 25L6’s and a 6SA7. It also leads to pin 6 of both 6SK7’s Any info on what value would be much appreciated. Thanks!
September 20, 2017 at 3:21 pm #9556HolderAccount
Forum Participantnot sure about the value. can you read any of the markings? is it open? I believe that was a local manufacturer to BC, so that might make it a bit special . I once had a table set and gave it to a fellow member who was in touch with one of the daughters or granddaughters who want it for a keepsake. most of the others I have seen locally were pretty plain looking consoles
maybe someone else could guide you through trying to look at tube voltages ( you could compare to the RCA manual for the nearby tube pinouts) Perhaps that could give you some idea of the voltages expected for the tubes it has. Maybe you could use subsitution of other resistors until you arrived at something that gave you a realistic voltage drop. Unfortunately Im not technically savvy enough to help with this as much as I;d like to be able to, but others with more electronics might be able to help more.
September 20, 2017 at 6:43 pm #9566HolderAccount
Forum ParticipantThanks for the reply. After much research/trial and error, I was able to get the set singing again with a 27 ohm resistor. I had to replace a number of other out of spec resistors, tubes and all the caps of course. Alignment was waaay off as well. Not a real power house of a radio but at least it’s up and running. There is nothing available, that I could dig up, for service data on this unit unfortunately.
Rod
