I need to test two Rogers Majestic radio tubes, 6B6M and a 6K6M if anyone could help me with the code, I would appreciate the information. I have a Stark 9-66 tube tester.
Thanks Bob Cassidy
This topic was modified 8 years, 9 months ago by .
Bob, Justradios has a list of substitute tubes here : http://www.justradios.com/typeM.html
Your 6K6M is the same as a regular 6K6. The “M” at the end just means “metal” for the metal spray coating that was applied to the Rogers tubes. As for the 6B6M it crosses to a 75M. https://www.radiomuseum.org/tubes/tube_6b6m.html
It is the same as a 6Q7 or 6Q7G
Hope this helps…
Tony
Too bad you didn’t have a 9-55 otherwise I could scan and send you all of my cards. They say the 9-66 was first made in the late 40’s and given this mine is probably as old as the radios I have. Other than this I have two Heathkit tube testers with the rolled up paper you scroll through by turning knobs. I just need to find a tube tester to test these.
