Home › Forums › Electronics Restoration › Rogers Model Ten-50 Knight missing power transformer
  • #14869
    Hi Folks
    I’m trying to figure out what power transformer I could use to replace the missing one on this chassis. A Rogers Majestic Ten-50 “Knight” The schematic show 230 Volts plate voltage.
    There is 6.3 filament and 5 volt for the rectifier. If my calculations are right I would need about 205-0-205 volts? 230v + 60 volts drop from rectifier / 1.414. = 205V CT? I look through the Hammand product page but there doesn’t seem to be anything in that range with both filaments. Has anybody tried anything different in this scenario? Maybe solid-state rectifier, but now i would need to drop the voltage etc. The 261M6 seems promising but the price is $122 plus shipping etc.for us Canadians. A lot of money to spend.
    Any suggestions would help me decide what direction to take
    John
    #14872
    Do you have a picture of the old one and some measurements for the mounting holes . Maybe someone may have a parts chassis with one that will work.
    #14873
    Have you considered using more than one transformer? The rectifier heater winding is isolated from the other windings so a separate transformer for that would work.
    #14875
    Thanks Sterling the transformer is missing, the measurements are 4 1/4 x 3 1/2.
    Thanks Alistair – I have considered using a separate transformer, I’ll have to see what i end up with.
    How to i add an image? Do i need to point to a url?
    • This reply was modified 6 years, 4 months ago by .
