Home › Forums › Electronics Restoration › Robert Simpson Company Serenader Model 5058 AM Radio/Phonograph
  • #7977
    I found this unit at a local flea market, and have been unable to find any data or information for this model. Serial # is 372275, made by Dominion Electronics Industries in Kitchner, Ontario for the Robert Simpson Company. The tube circuit operates an AM radio and a record player. The phonograph has speed settings for 33, 45, and 78 rpm records, and the phonograph shelf does not slide out as seen on other similar consoles.
    I would appreciate any insight regarding this unit.
    Cheers and thank you.
    #7979
    There is info here on a Sears model 5058. I do not know if it is the same unit or not.
    Good luck with your search.
    https://lcweb2.loc.gov/master/mbrs/recording_preservation/manuals/Silvertone%20Radio%20(Parts%20List%20and%20Instruction)%20(Sears).pdf
    Regards;
    #7980
    Thank you John. I tried, but the link was unable to be found, error 404.
    #7981
    Update John, found the link via Google, cheers
