Home › Forums › Electronics Restoration › Re57 motorboard questions?????
  • #3439
    I recently bought a Victor RE57.When I got it the wires to the turntable were not hooked up.. It is quite a system in there because it can make records from the radio or you can make your own voice on record.And you can of course play records.. All of the wires were not hooked up.. I need information about the hookup of the motorboard.. Any information would be of help.. Thanks Dan in Calgary
    #3442
    Inactive
    The RE57 is on page 5 of the ‘victor’ section in the RCC. It might help. If you can`t get a copy, send me your email and I`ll send you a high def jpg.
    #3443
    Thanks for the offer… I do have the schematics but they don’t show
    where all the wires go to the shut off switches that are controled by the arm. . There are two switches under the turntable,and there were no wires connected to them. I do know that they are to turn on the motor when the arm is moved over to the record. I do appreciate your offer,,,,Dan
    #3445
    Inactive
    Hi, in my schematic it shows two switches near the motor. One clearly turns the motor on/off, and the other a ‘pick-up shorting switch’ is connected to the audio input transformer. Unfortunately the connections are not clear in my copy. -Verlyn
