Home › Forums › Cabinet Restoration › QUESTION ON RADIOLA 16
  • #9423
    Hello,
    Are the two knobs on the Radiola 16 the same size as those used on the model 18?? The reason I ask is I an looking at buying a Radiola 16 that is missing the knobs. When I tried to put a knob on it that I borrowed from my model 18 I found that the Radiola 16 has a small shaft size. So did they use the same knobs with just a different inside shaft hole or are the outside dimensions also smaller??
    Pete Stratford
    Nova Scotia
