Home › Forums › Electronics Restoration › Nordmende Fidelio 300 repair
- This topic has 10 replies, 4 voices, and was last updated 5 years, 9 months ago by
Jean Marcotte.
February 4, 2021 at 6:29 pm #16188
Forum ParticipantGreetings to all from Lachute, Quebec… i have recently purchased a Nordmende Fidelio 300 with no sound on the right speaker. I have tested the right speaker using the left speaker wire and it does work, i have also looked for bad connections but without any success.
I have very limited tube radio knowledge and dont know were to look next, youre help would be greatly appreciated, i’am including pictures of the radio.
Best regards,
Gennaro
This topic was modified 5 years, 9 months ago by
February 4, 2021 at 6:44 pm #16191
garykusterForum ParticipantHi Gennaro,
here’s a link to information about your radio. If you click on the schematic, you should be able to print it out.https://www.radiomuseum.org/r/nordmende_fidelio_6630.html
Gary (In Montreal)
February 5, 2021 at 4:23 am #16194HolderAccount
Forum ParticipantHi Gary….i have very little knowledge and would not understand a shematic. I noticed youre in Montreal, could u take a look at it?
Gennaro
February 5, 2021 at 5:51 am #16195HolderAccount
Forum ParticipantGenarro, my advice is to learn how to read a schematic, and learn about electronics. You might find someone to do the repair, but this group is doing what it does because it enjoys the challenge of fixing radios, rather than the challenge of getting someone else to fix it as a favour. We’re willing to help, but it sounds like you won ‘t be able to give us any information about the radio so that we could help you.
February 5, 2021 at 6:14 am #16196
garykusterForum ParticipantGennaro, Although I speak German, I’m not that fluent in German radios. If you don’t have a basic understanding of Schematics at a minimum, I doubt this forum will be of much use to you. I’m pretty sure I recently came across an ad for someone specialising in German radios in the Montreal area.. I will try to find out the contact info.
February 5, 2021 at 7:20 am #16198
garykusterForum ParticipantGennaro, Although I speak German, I’m not that fluent in German radios. If you don’t have a basic understanding of Schematics at a minimum, I doubt this forum will be of much use to you. I’m pretty sure I recently came across an ad for someone specialising in German radios in the Montreal area on Facebook .. I will try to find out the contact info.
This reply was modified 5 years, 9 months ago by
garykuster.
February 5, 2021 at 10:54 am #16200HolderAccount
Forum ParticipantThanks to all for your help!
February 5, 2021 at 1:23 pm #16201
garykusterForum ParticipantGennaro, here’s the link to the repair guy specialising in German radios. I have not personally had any dealings with him, so you’re on your own.
February 6, 2021 at 6:04 am #16202HolderAccount
Forum ParticipantThanks Gary….wondering if you knew another radio technician by the name of Gary, he lived in Anjou?
February 6, 2021 at 6:12 am #16203
garykusterForum ParticipantNo, can’t say i do. I’ve only been at this for a couple of years and still learning the ropes as well.
February 7, 2021 at 7:37 am #16223Jean Marcotte
CVRS MemberHi Gennaro, it’s not a speaker or speaker connection problem. This is a stereo set and one channel is not operating. I would rule out a faulty tube also since the same tubes do both channels. I would suspect a bad contact in a switch wich is quite common in german radios with “piano” type selectors. You can try spraying the switches with contact cleaner (Deoxit is the best) and play with the switches to see if the dead channel comes back to life. If that does’nt work I’m not a specialist in german radios but I can have a look at it. I live in Laval.
