Home › Forums › Electronics Restoration › New transformer replacement question
  • #16767
    Hi,
    I’ve been looking at new transformers and have a question. I need a 2.5v secondary for the filaments and pilot lights. All I can find are secondary’s with 6.3v. The 6.3 is center tapped so I could get 3.15v but I don’t know if that little extra voltage will blow out the filaments. It’s a 5 tube set and uses an 80 rectifier and has 2 pilot lights.
    Is there a way to get around this or am I worrying for nothing?
    Is there a source for transformers with the 2.5v secondary.
    The transformer I’m looking at is a Hammond, P-T273DX.
    Thanks!! 🙂
    #16768
    Bruce Morgenstern
    Hi Shayne
    I have attached a good listing of Hammond transformers which shows quite a few 5 volt centered tapped transformers. I am not sure if you have a source where you were planning to order one from if not I have used Mouser Electronics in Kitchener and any time I have used them been very satisfied.
    Hope this helps
    Bruce
    Mouser Electronics, Inc.
    137 Glasgow Street
    Unit 475 A
    N2G 4X8 Kitchener, ON
    Canada
    Local: +1 800 346 6873
    Thanks very much Bruce!
    I’ll check it out.
