Home › Forums › Electronics Restoration › Magic Eye
- This topic has 6 replies, 4 voices, and was last updated 9 years, 11 months ago by
June 2, 2016 at 12:15 pm #7824
Les DicksonCVRS MemberI’m working on a Marconi Model 243 which has a magic eye tube 6U5. I want to test the radio after replacing caps and resistors but don’t want to spend the amount of money needed to replace the magic eye tube until I’m sure everything else is functioning. Is it possible to test without a functioning 6U5? I know this is used as a visual aid in tuning stations. I don’t understand how it will impact voltage drop or the function of the radio if it’s not working. Any suggestions would be greatly appreciated.
June 2, 2016 at 5:02 pm #7826Greg Bilodeau
Forum ParticipantLes, go ahead, the radio does need the 6U5 to operate and will make little difference in set voltages.
Gregb
June 2, 2016 at 5:03 pm #7827Greg Bilodeau
Forum ParticipantSorry, typing to fast, DOES NOT Need
Gregb
June 3, 2016 at 9:15 am #7828
Les DicksonCVRS MemberThanks Greg.
November 21, 2016 at 2:44 am #8222HolderAccount
Forum ParticipantWasn’t sure where to post the following, but this seems as good a spot as any. Anyone who patrols eBay may have noticed that a vendor in Taiwan has been pedaling a real treasure-trove of 6E5 eye tubes. To date, he has sold over a thousand of them! They are going for $20 a throw right now. I bought 10 of them when they were $10 each, and a friend in Georgia bought an equal number. These are Japanese Toyo tubes and, when operating properly, have a nice bright phosphor. There is a caveat, however. One of mine was defective right off. The glass envelope had become separated from the base in shipping (I thought). I inserted another in my Stromberg 694 and it worked fine — for a while. One day, it was dead. Sure enough, the envelope had separated from the tube’s base while in the radio! My friend had experienced similar problems with his batch of Toyo 6E5’s. The solution; super-glue the bases to the envelopes for starters. Even when firmly attached, the leads appear to have a tenuous electrical attachment to the base pins, at best. So here is where a good old fashioned solder pot and some quality liquid flux come in to play. Once re-soldered, these tubes should last a good long time.
November 21, 2016 at 7:39 am #8224Dan Walker
CVRS MemberA friend of mine bought a couple of these tubes and he liked them. he said they are very bright ,so I ordered
a couple for myself.
I don’t need them at the moment but I know I will at a later date.
Dan in CalgaryNovember 21, 2016 at 3:03 pm #8232HolderAccount
Forum ParticipantThey have a super-bright phosphor. You will be happy with them. In my continuing adventures in Stromberg 694 desecration,I am replacing the perfectly good 6U5 eye with a super rare 6T5, normally found only in Zeniths. The reason? I have a couple of them, and the bulls-eye display means you don’t have to bother lining up the tube just so…
