Home › Forums › Show & Tell › Introducing my new humble FM Stereo Encoder project..
- This topic has 2 replies, 2 voices, and was last updated 8 years, 5 months ago by
May 8, 2018 at 3:07 pm #10100
Forum ParticipantHi guys,
I just finished my new FM Stereo Encoder project
based on the PIRA CZ stereo encoder.
http://www.pira.cz/eng/stk2en.htm
I use it with my old reliable Marconi 2022E RF generator
(connected to its external modulation input)
to generate a nice and sharp Stereo encoded FM audio signal
to some of my vintage FM radio to be repaired and aligned..
I had to build an interface to connect to the PIRA encoder
and also added a switchable 500hz tones to test channel separations.
This project of mine is viewable here:
http://www.arcenson.com/projects/FM_Stereo_Encoder/Enjoy !
Jean-PierreMay 16, 2018 at 9:15 am #10113HolderAccount
Forum ParticipantFor those who’d be interested to get more detailed information
about my FM encoder project I just created 2 new YouTube videos
about this project. You will be able to see the encoder in action.FM Stereo encoder project part 1
FM Stereo encoder project part 2
And please.. forgive my french accent.. I did my best.
Cheers !Jean-Pierre Desrochers
May 29, 2018 at 1:27 pm #10136HolderAccount
Forum ParticipantI have a little gizmo that is used to interface a cell phone or MP3 player with my car stereo. it just plugs into the lighter and it has a typical audio jack for the input. and cost was low. would think my device pale in comparison as far as acoustics ? Ive used it before but not for a long time. Ive got a similar device that was used to make car AM radios also play stereo. That one doesn’t broadcast over the air but instead the radio antenna daisy chains through it so I guess it converts the FM audio and sends it into the AM car radio via the antenna cable. In a similar manor you tune the car Am radio into about 800 or so to get the FM signal from the separate little tuner. it’s good for old cars where you wan the look of the old AM radio.
I picked up the Am one used thinking I could use it in my old car as the collector plates dont; allow new sterios. Ive been thinking of just trying to connect it to my AM radios through the antenna in order to play FM over them. I’d like an SStran or something similar but I thought these car radio devices might do the trick. Not sure how great the audio will be though.
I always thought it would be neat if one could separate both channels from the FM signal and then re-broadcast them separately over AM, then one could use two old radios to each play their side of the stereo sound. I have no idea if it is practical but wouldn’t it be neat to get stereo from two old radios?
Im not so technically advanced so my post probably sounds a bit off. This package seems very well thought out, It sure looks professional the way you made the faceplate and box fit so well.
