Home › Forums › Electronics Restoration › I need help with dial glass “Marconi model 84
  • #15775
    If any one has any information about the Marconi model 84 dial glass, please let me know.
    I ordered the pieces of glass with the station numbers on them, but I need to know
    how the glass is installed. There are three or four pieces of glass.
    When I got the radio all the glass was broken, and it came out in pieces.
    Any help is very welcome
    Dan in Calgary.
    • This topic was modified 5 years, 11 months ago by Dan Walker.
    • This topic was modified 5 years, 11 months ago by Dan Walker. Reason: spelling error
    #15789
    Gordon Dann
    You will need to remove the chassis from the back and replace the printed glass witch will attach to it then a plan piece will fit on the front with some clips and screws. I just finished a model 118 and that’s how mine went together and I would think yours will be the same. where did you get the printed glass as I have a radio with a cracked glass and the only place I could find that would do it (at a high cost) was radiodaze in the U.S. cheers Gordon
    #15791
    Thanks for the reply.
    I have recapped the radio already , and am waiting for the dial glass
    I did get all the information about the dial glass from a fellow member
    This is a little more complex than you think. There are three pieces of dial glass and I have ordered them from Radio Daze
    It is quite different than a model 118. I had a 117 , 138 and an 85, but this is different.
    I had the make a curved front glass out of a special plastic for the model 85 and also for this model 84.
    Thank you for the reply
    • This reply was modified 5 years, 11 months ago by Dan Walker.
