Home › Forums › Electronics Restoration › I need a clear schematic for a Marconi
- This topic has 9 replies, 5 voices, and was last updated 5 years, 9 months ago by
Dan Walker.
January 23, 2021 at 8:47 am #16057
CVRS MemberI have a Moroni console model 70 and I got the schematics form Pacific TV, but they are not very clear.
I also have the Marconi book with the schematics in it for that model, and it is hard to read, especially when the numbers are blurred.
Does anyone have clear schematics for this radio?
If you do please let me know . Thanks
Dan in CalgaryAttachments:
January 23, 2021 at 11:15 am #16060
John GreenlandCVRS MemberDan,
I checked here : http://www.nostalgiaair.org/Resources/download.asp?FN=\M0029441.pdf
And the copies he has from the RCC manuals does not appear to be good . Are they any better than what you already have ?
Good luck with your search !
January 24, 2021 at 8:36 am #16083
Les DicksonCVRS MemberHi Dan, I checked at radiomuseum.org and those look fuzzy too, have you compared those to what you have?
January 24, 2021 at 8:58 am #16093Dan Walker
CVRS MemberThe best I could come up with are the ones in the Marconi book that I have. They are still blurry, especially when it comes to
finding out the numbers of the caps I checked Nostalgia air and they are the same.
I might have to work with what I have.
I would like any information concerning this radio especially the tuning shaft as it has a spined shaft that runs a tuning wheel on the main caps.
It seems like every radio has some sort of different system for running the tuning caps and the dial.Dan in Calgary
January 24, 2021 at 8:38 pm #16107Jean Marcotte
CVRS MemberHi Dan, here are the 300dpi scans I made from the RCC.
Jean in Montreal
January 25, 2021 at 9:56 am #16110Dan Walker
CVRS MemberThanks Jean; It looks like they might be a bit better than the ones I have , but I can’t seem to get them in to a form where I can see it .
. I tried to copy it to my documents , but it was much too small.
I don’t know how to make the copy you sent me larger so I can read it better.
Dan in Calgary.January 25, 2021 at 12:39 pm #16112HolderAccount
Forum ParticipantHi Dan click on schematic and let it open up and you can click on grey bar on bottom of schematic where then on your bottom screen it should show open files where you can then open file and print or enlarge the schematic and see each section. Hope this helps. Not very computer sauvy .
January 25, 2021 at 6:39 pm #16115Jean Marcotte
CVRS MemberRight click on the thumbnail and select “Open in a new window”. You should have it original size.
Jean
January 25, 2021 at 6:41 pm #16116Jean Marcotte
CVRS MemberSorry, “Open link in a new window”.
Jean
January 26, 2021 at 8:28 am #16118Dan Walker
CVRS MemberI did open it in a new window, and if I zoom in on my computer I can make out most of the symbols . I also printed a copy and it is a little better.
I tried to move it around so I can print two halves and each one would be a little larger, but I could not find anything on my computer
That would do it
On some things I can ”take a snapshot” and print it , but no luck so far.
Thank you for the copy that is better than the ones I have.
Dan in Calgary. -
