Home › Forums › Electronics Restoration › How do I remove a knob from a ge JK 70
- This topic has 3 replies, 2 voices, and was last updated 13 years, 11 months ago by
November 14, 2012 at 11:20 am #3564
Forum ParticipantThe trouble with the Knob on the Ge canada Model JK 70 is it is 2 Piece and it is hard to remove, It is 2 piece because it is on a roteing switch/selector. The knob is bakelite and unless it is removed properly from the post it can break. Now How to remove this knob I am Uncertin How to do just this does anyone here know how to remove a knob it is 2 piece.
November 15, 2012 at 6:25 pm #3588HolderAccount
Forum ParticipantIts not a set screw type – I just pulled the knobs off mine – If yours are stuck – there are two methods that I would try – first – a sharp rap on the middle of the knob inward – toward the back of the radio – this may break whatever corrosion is holding it on – not too hard – you don’t want to break the knob – and be very careful of the dial glass.
Next – take some strong string or butcher cord – wrap it around the back of the knob – and pull toward you with the free ends.
Removing the chassis screws and pushing the chassis toward the front of the cabinet may gain you a little more room to get the string behind the knob.
Good luck.November 16, 2012 at 3:02 am #3590HolderAccount
Forum ParticipantThank You awesome idea I never thought of this Ill try these methods and let you know how they work out good i am sure . This was a one owner radio I was schoked to see it has an eye tube is this a rare radio it was purchased in canada what about the voltages between here and canada>??
Many Thanks for all the help from willliamNovember 18, 2012 at 4:43 pm #3595HolderAccount
Forum ParticipantWilliam – here in Ontario – its a very common radio – they must have been a big seller because there are a ton of them – in GE and RCA versions – as well as consoles – there were a few variations as far as tube complements and antennas – good performers – its been a few years since I did one – but from what I remember – biggest problems are push button assembly (contacts get dirty and oxidized)- rubberized wiring needs replacing, and resistors drifting off value.
Voltage is the same as US – it may have a 25 cycle transformer – but that won’t matter – they generally had physically smaller power transformers that tend to run hot – so you may want to reduce the line voltage by installing a bucking transformer – there are numerous articles
on the web about that.
It is a good radio for a new to intermediate restorer – good for learning a lot of things – and will test your ingenuity for operating and aligning out of the cabinet. -
