Home › Forums › Electronics Restoration › Electrolytic capacitor polarity in schematic.
  • #13317
    In the attached image, for the electrolytic caps, what is the polarity?
    #13321
    Theyr’e drawn to look a bit like a can with a filling, so the outer can is negative. And in the left-hand one, you see that this is connected to ground, as pou’d expect from a large smoothing electrolytic.
    #13328
    I wondered if the symbol represented a can, but wasn’t sure enough to gamble. The original cans had been removed so I didn’t have much to go on. I’ve not seen that particular symbol for electrolytic capacitors before. Thanks for the help Alistair, much appreciated.
