Home › Forums › Show & Tell › Deco Westinghouse
- This topic has 12 replies, 4 voices, and was last updated 2 years, 11 months ago by
August 15, 2020 at 5:36 pm #15140
garykusterForum ParticipantIt’s only the case for $50, but I’m in love with the Deco lines!!! How impossible would it be to find the “guts” for this
Update/ It’s a Raymond Loewy Art Deco Skyscraper radio Westinghouse WR 15 Columnaire Jr. But I think/hope this one came with a clock or else someone cut a big hole in the front! The speaker fires up!
August 16, 2020 at 11:03 am #15144
garykusterForum ParticipantIf anyone is still around here, I purchased the case which is mint and I’m looking for the clock and chassis if someone has a lead on one.
August 16, 2020 at 2:37 pm #15145HolderAccount
Forum ParticipantHi Gary, did a little research and found that the rca r-11 chassis is the same also.
August 16, 2020 at 3:03 pm #15146
garykusterForum ParticipantHi Sterling, Thanks for the info, I hunted around as well and it shares the chassis with several RCA tombstones, but I got conflicting information. One place said RCA chassis r10, another said chassis r15 and R-7. I’m less worried about the chassis and more on the hunt for the missing clock. I am pursuing some leads.
August 16, 2020 at 3:36 pm #15147HolderAccount
Forum ParticipantPerfect let me know what you find out. Will the wr8 clock work? There seems to be more of them around.
August 18, 2020 at 3:12 pm #15148
garykusterForum ParticipantI’m drawing a blank with the clock. Sterling, if you see one working or not, that would be amazing I’ve decided to install modern innards with a digital screen where the tuner would be. It won’t affect the outward appearance.
August 21, 2020 at 5:38 pm #15158HolderAccount
Forum ParticipantHave you tried any of the face book groups for one?
August 26, 2020 at 6:49 am #15167
garykusterForum ParticipantNo I haven’t,but I’m putting it on the back burner for now. I found someone in Toronto that has a WR8 with the same clock and they sent me a pic of the clock face which I should be able to enlarge and mount on MDF with a battery clockwork for now.
Thanks, Gary
September 21, 2020 at 6:11 am #15319fedorat
CVRS MemberHello Gary
The WR8 is the american version of the canadian 801, it has an 8 inches square clock. What you need is the american WR10 or the canadian 101 wich has a ten inches rectangular clock.
Daniel
September 21, 2020 at 6:16 am #15320
garykusterForum ParticipantThanks for the heads up Daniel. I’ve only found one in Toronto,but it’s still in the case and too much coin. I have given up trying to find one and will likely graft in another clockwork.
Thanks again, Gary
February 23, 2023 at 11:30 am #15321fedorat
CVRS MemberHere you have the WR8 or canadian 801 with square 8 inches clock https://repository.duke.edu/dc/adaccess/R0607
and here you have the wr10 or canadian 101 with 10 inches rectangular clock https://repository.duke.edu/dc/adaccess/R0169Daniel
November 18, 2023 at 3:15 am #32333HolderAccount
Forum ParticipantGary,
Recently, I had bought a vintage clock off of ebay because I thought it would be fun to restore and I liked it’s look – see attached.
It was in hurting shape, dust grime some dings and the second hand somewhat out of shape.
But after a thorough cleaning I found it keeps great time.
I am not a radio collector, I am into restoring vintage clocks.
Anyway, I was trying to find parts for a New Haven Westinghouse steeple clock and low and behold came upon what I believe to be my mystery clock – Westinghouse Columaire WR15.
Face dimensions 10-5/16″ x 8-1/2″
Then I started doing research on the Columnaire and found your posting.
I believe that it is the clock for the WR15 – or am I wrong?
PaulNovember 18, 2023 at 3:18 am #32334HolderAccount
Forum Participantresend from previous post with images resized
