Home › Forums › Electronics Restoration › Canadian General Electric Model A -63 CONDENSERS ?
  • #16710
    rudedaddy
    I am working on this 1935 radio and I am having a problem with the designations on the condensers … numbers like 66139-1 and G27 on some of them . Is there a code list to change these numbers to values ? Like Philco has a code list telling what values are in the bake backlite condensers. This chassis was also used by RCA too….????
    #16711
    If you follow this link it leads you to the schematics. There you can find the values of the various capacitors.
    It does tell you [for example] that C29 is 16 MFD , and C28 is 8MFD.
    All the values are there, just follow the schematics and they show the values of the smaller ones also.
    I hope this helps.
    http://www.nostalgiaair.org/pagesbymodel/753/M0007753.pdf
