Home › Forums › For Sale / Wanted › Audio transformers
  • #5979
    Jean Marcotte
    Hi everybody,
    I need two audio transformers in good shape for a Westinghouse RC (RA/DA) or for a Radiola III that uses the same transformers.
    Thanks.
    Jean Marcotte
    Montreal
    #5980
    Hi,
    If you have the original transformers Hammond makes a 124C coil that can be put on the steel inside the transformer shell.
    Also they have a whole transformer refill with steel and terminal board at a higher price.
    #5981
    Jean Marcotte
    Many thanks Ed. At least I have an option if I can’t get the original parts. The Westinghouse RC is my SQCRA restoration contest radio so I try to get the original parts. If I can’t get the real thing I will probably go for the Radiola III replacement. With a bit of imagination I might be able to make them look old.
    Jean Marcotte
    #5982
    Hi Jean,
    Both those suggestions fit inside the original outer cover of the transformer. The outside appearance and shell would be original, the insides new and hidden.
    #5983
    Jean Marcotte
    Hi Ed,
    In the Radiola III the transfos are encased but in the Westinghouse RC (RA/DA) the coils and iron are visible. That is my problem. If I use new parts I will need to make them look old. Whatever the outcome I will post pictures of the final result (or failure…).
    Jean
    #6068
    Jean Marcotte
    Here is the final result. Since I had no reply for originals and time is not my luxury I finally got two 124C coils. After sanding the very rusty 29 steel plates of the transformers (29 X 2 sides X2 transformers = 116 sides) and coating them with lacquer (on one side only) Here they are.
    Thanks Ed.
