Home › Forums › Electronics Restoration › What’s this part?
- This topic has 8 replies, 5 voices, and was last updated 4 years, 1 month ago by
John Bartley.
September 18, 2021 at 6:54 am #17177
robert clausen
Forum Participanthttp://pacifictv.ca/schematics/sw20data.pdf
Hoping one of the members could confirm what this part is. I think it may be a duo cap for C-19 and C-12 on the schematic but I’m not sure. Looking for someone that may be able to either confirm that or tell me what it is before I connect a replacement.
September 18, 2021 at 7:35 am #17179Dan Walker
CVRS MemberIt looks like it is a capacitor, but I can’t say for sure.
You would have to trace the leads from the unit and see where they go to and check what you find with the schematic.
I have had capacitors in the same cardboard containers before,but that does not mean that yours is a cap or multi caps in one container.
Here are some photos of one that I re stuffed from a Rogers 6R932.
Dan in CalgarySeptember 18, 2021 at 7:36 am #17184Dan Walker
From the photo we can’t see how many leads come from the unit.
Dan in CalgarySeptember 18, 2021 at 9:35 am #17189robert clausen
Forum ParticipantThis is a better pic. The reddish wire goes to pin 2 of tube 42, a black wire goes to the second section of the resistor panel and a blueish wire goes to the terminal board.
September 18, 2021 at 9:59 am #17191
Les DicksonCVRS MemberI’ve seen this and like Dan says it’s a container of capacitors that you can stuff with new ones. Just be sure to follow the schematic to determine the needed values.
September 19, 2021 at 9:27 am #17194robert clausen
Forum ParticipantThanks Les and Dan for your assistance. I will trace the wiring before securing anything.
September 19, 2021 at 5:05 pm #17195
John GreenlandCVRS MemberRobert,
If you are reasonably certain that one lead connects to pin 2 of the audio output tube, a 42 , then it is quite likely that these two caps are C11 a 0.05 UF capacitor and C10, a 0.005 UF cap.
Both have to do with the audio output.
When you replace them you should probably use caps rated for 600 volts.Good luck
John G.
VO1 CATSeptember 19, 2021 at 5:52 pm #17196Dan Walker
CVRS MemberPersonality I would do a double check and make sure where the wires coming from the cardboard box are going to.
I have not seen such a small value [.05 and .005] in a cardboard enclosure..Just my thoughts
Dan in Calgary.September 24, 2021 at 5:11 pm #17229John Bartley
Forum ParticipantHave a look at C12 (12UF at 25VDC) and C19 (4UF at 350VDC)
The values are printed on the cardboard cover …. 4/350 and 12/25
cheers
