Home Forums Radio Parts Wish List Push buttons needed for DeForest crosley” FOUND”’
  • #17893
    I have a De Forest Crosley table radio with out push buttons
    It is a model 8D731 See attached photos.
    The width of the flat shaft is 3/8 of an inch.
    thanks
    Dan In Calgary
    • This topic was modified 3 years, 9 months ago by Dan Walker.
    • This topic was modified 3 years, 9 months ago by Dan Walker. Reason: CHANGE TITLE '' FOUND''
    #17995
    Ralph Spracklin
    Morning Dan
    If you look closley at either of the two chassis view photos you posted above, you will notice that the pushbutton mechanism on your radio was designd to accomodate the use of nine pushbuttons. I think this could mean that there is also out there another radio model that also uses the same setup as yours. I have searched the net, but as of yet I have not been successful in my search. Should you find it, it may open up new prospects as to a donor canidate radio???
    However having said that, these pushbuttons seem easily duplicated. In the pictures they look as though they are crafted or molded from white metal or soapstone. You could also cut them from Gray Marble with a tile saw.
    Just thoughts going through my mind.
    #18000
    Hi Ralph;
    This radio has only six push buttons. [attached photos]
    The original ones are or were made of the same stuff that most of the push buttons
    were made of.
    i have put the word out on ARF also,,, but so far no response.
    I thank you for your input
    I got some of these push buttons from Tony F
    thanks Tony
