Home Forums Electronics Restoration General Electric World Monitor P-990A Antenna
  • #11945
    tobin
    Hello,
    New to the hobby. Looking for some help with the antenna on a GE World Monitor P-990A.
    Trying to figure out the correct way of attaching the FM antenna. It’s very loose. The SW antenna is stable.
    Could it because of a fault? Not sure if a metal tab has broken off. See yellow rectangle in attached photo.
    Or is a piece missing that tightens the antenna from the inside?
    Thanks in advance for any assistance.
    • This topic was modified 6 years, 5 months ago by tobin.
    #11964
    You can clearly see where the metal tab has broken off. In pic 2445-2, you can see the retaining nut for the antenna assy. Remove the nut and try to reassemble/repair the antenna assy perhaps using something like JB Weld or epoxy. You could probably hold it together with a hose clamp while it dries and then reinstall using the nut.
    Unless the spring exerts enough tension on the ball part of the antenna mast, (which it won’t with 1 tab broken) it will always flop around like a wet noodle. It looks like the angle bracket on the inside top of the radio is insulated from the chassis and if this is the case, attach your antenna lead wherever you find a suitable screw etc.
