Home Forums Cabinet Restoration Canadian General Electric C544 Grill
  • #35247
    Lee Whitehead
    I have this Canadian General Electric C544 radio to restore but have a problem with the dirty grill. It appears to be something similar to Bakelite so I don’t know what to clean it with. Soap and water didn’t work. Would a jewelry cleaner be safe?
    • This topic was modified 3 months, 3 weeks ago by Lee Whitehead.
    The grille looks like the best part of the radio. Have you disassembled the radio? Can you not separate the cloth from the grille itself. Would be a lot easier to clean it that way no matter what you use.
    #35252
    Lee Whitehead
    Its not actually cloth, it is the same composite material as the grill and part of it. I tried Simple Green and even lacquer thinner on a corner with no luck. I’m going to paint it with some Testor’s gold, just a light spray. Thanks for your response.
    #35253
    HI all,
    Go to Home Hardware and buy a small can of Toluene. It will clean just about anything.
    Try it sparingly on a part of the grill assembly that you can not see.
    Check it out on the internet if you want more info.
    TTFN
