Home Forums Electronics Restoration Battery Eliminator System
Viewing 15 posts - 1 through 15 (of 17 total)
  • #4837
    Rhonda
    Hi All:
    I am in the process of restoring an old farm radio that ran on an A and B battery. So I am designing an eliminator for it that will be solid state, efficient and will have a few other neat features. I have the basic idea and configuration figured out and will start the build in a few weeks.
    In total there will be four power supply topologies required to fit into the box – a true smorgasbord of technology that will be easy to build and maintain.
    Would anyone else be interested in something like this? Send me an e-mail if you would like more information.
    Regards,
    Gerry Shand
    780-910-7031
    #4842
    mr-moe
    Not to be picky Gerry, but a farm radio is one that runs on a single dc voltage. Sometimes seen with set of alligator clips that would clip to your tractor or car battery (6 volts of the day) or 32 volt battery pack that would be charged by windmill or stationary engine with charger.
    Radios that have different sets of batteries A and B or even a C were just called battery operated radios.
    Sometimes confusing
    Moe
    #4843
    Rhonda
    Thanks for clearing that up Moe. So a “Farm Radio” is acually a type of battery operated radio.
    I got the two confused as I can remember some of my relatives who farmed that had battery operated radios.
    In the end, I guess what got bought for a radio came down to ingenuity (using the radio with what they already had on hand) and affordability.
    Best,
    GWS
    #4844
    Hi Gerry/Mr Moe,
    Yes, I guess that is correct – one definition of a ‘farm radio’ is that they are a subset of the ‘battery radio’ class. I would say that if we are being pedantic, such a radio would include a vibrator power pack to convert the 6v, 12v or 32v to a suitable high voltage for the B supply – I have one or two in my collection like that, eg. Zenith ‘cube’. However, the term ‘farm radio’ is generally used to encompass battery operated radios, even if they relied on high voltage battery as the B supply.
    #4856
    Rhonda
    Well I have the sequencing control circuit for this up and running. This powers the tubes up and down in a controlled fashion to get the maximum life out of them.
    Right now I am using a Basic Stamp 2 as the controller but might migrate the control platform to a PIC 16F84 the like.
    So the eliminator is going to have a really neat amount of technology in it.
    Regards,
    Gerry Shand
    780-910-7031
    #4866
    Rhonda
    I now have a schematic now roughed out that I can start breadboarding the prototype from. This project is going to require a few power supply components I have never played with before so it’s going to be fun and interesting times.
    I also want to make this supply universal enough where it can be used in any vacuum tube design whether it be a retrofit or a scratch design.
    Now to come up with a name for it. I am thinking of the SSP-1 (small, sweet and powerful). The -1 denotes the maximum plate voltage design for 170 VDC.
    Gerry Shand
    780-910-7031
    #4868
    Ed Stone
    Looking forward to seeing the final design Gerry – power supplies for farm sets and the 1920’s battery sets are always popular construction items. I have several such sets that need power supplies (I have to connect each one up to my one power supply when I want to use it) – it would be good to make a few such supplies so they could always be connected rather than having to fiddle about with connections each time (and risk making a mistake!). So make sure its cheap to construct…
    Ed
    • This reply was modified 2 years, 11 months ago by Ed Stone.
    #4875
    Rhonda
    So just a general question: what would you expect to pay for an item like this? Let me know your thoughts please. Thanks.
    #4936
    Rhonda
    Update: I am having a setback getting the filament power supply to function. Getting a lot of heat. So trying a few other topologies to see what I can come up with as an alternative.
    #5043
    Rhonda
    Today the filament power supply is prototyped and working!!! For the past 24 hours it has produced 1.5 VDC at 3 A. The next load test will be 12.6 VDC at 3 A. The primary pass transistor gets very hot but has not gone into thermal shutdown – so it only needs a bigger heatsink. The one I have was what I had laying around in the lab. Now to get all the PCB components onto a circuit board.
    #5058
    Robin in Kansas
    Great job, Gerry! I love the look of all that spaghetti! I don’t understand it but I love the look of it! I’m with Ed on this. I need a couple to keep from screwing up the connections, too. Just figure out what the parts cost and what your time involved is worth to you and let us know what the charge for one would be.
    #5059
    Rhonda
    Hey Robin:
    This is just for the filament supply. I need two additional supplies for the B and C voltages, an interface board to prevent ka-booms due to bad connections, and a sequence control board so the radios are brought up and down nicely so the tubes aren’t stressed necessarily. So lots of work still to be done. And most of this spaghetti will migrate to a PCB – it’s easier to fix a prototype problem with spaghetti than it is to make a board and find your design has issues (been there, done that). So stay tuned to this thread for any updates.
    #5060
    Robin in Kansas
    I love your car in your profile picture, too, by the way!
    #5151
    Yeah – what sort of car is that Gerry? – looks like one of the old UK ‘Invalid Carriages’ – per the photo below (just kidding). I bet it is some rare Messerschmitt or something.
    #5156
    Rhonda
    Hi Gerry and Robin:
    The vehicle is a take off of the Gizmo EV that was produced in the northwest United States. The frame and shell are fine but the DC drive system needs to be upgraded to an all wheel drive using AC variable frequency drives and the steering mechanism needs to be changed to a motorcycle handlebar arrangement. It is closer to a Peel Trident P-50(?) but much heavier due to the battery bank.
    Regards,
    Gerry Shand
    780-910-7031
