Home › Forums › Electronics Restoration › Tube 6AQ5 vs 6AQ5A "Heater Difference"
- This topic has 5 replies, 4 voices, and was last updated 7 years, 9 months ago by
Don Henschel.
January 12, 2019 at 11:18 am #11020
Les DicksonCVRS MemberI’m working in restoring a PYE model 53D and the 6AQ5 tube is not good. I have several 6AQ5A tubes but according the the radiomuseum web site the heaters are different. When I look at the data sheets the only difference I can see is that the newer 6AQ5A has “heater controlled warm-up time.”
Any advice on substituting the 6AQ5A in?January 12, 2019 at 12:30 pm #11026HolderAccount
Forum ParticipantAccording to Wikipedia,
https://en.wikipedia.org/wiki/6AQ5
the 6AQ5A is an industrially rated 6AQ5 with the modified heater action as you said, so it will be OK in your radio.
January 14, 2019 at 6:40 am #11028
Les DicksonCVRS MemberThanks Alistair, much appreciated. I never thought of checking Wikipedia.
January 14, 2019 at 10:43 am #11029
John GreenlandCVRS MemberHi Les,
In checking the RCA tube manuals that I have, the 6AQ5 from the 1947 version shows all kinds of caveats with using the 6AQ5 in series heater string configurations. None for parallel.In the 1960 version of the tube manual, the 6AQ5 is shown as discontinued and replaced by the 6AQ5-A which has been designed with a heater which can easily be used in series configurations.
It seems that this particular tube was a common one in TV’s and seems to be the big reason for its re-designed heater.Basically the tubes are interchangeable in parallel configurations.
BTW — Fair Radio Sales in Lima, Ohio are showing a listing for 6AQ5 pull outs in a lot of 10 for $10 US.TTFN
John G.January 16, 2019 at 9:39 am #11054
Les DicksonCVRS MemberThanks for the info John, much appreciated.
January 18, 2019 at 8:47 am #11056Don Henschel
Forum ParticipantI’m surprised the 6AQ5 goes that far back. I’m used to seeing the common 6V6 commonly used even as late as 52 or later and of course if you desire a much louder “shindig” a 6L6. What surprised me is how much higher the voltages and wattage are on that iddy biddy little peanut. No wonder they run so hot in comparison. My Macaroni in my 1950 Mercury has the 6V6 crammed tightly against the vibrator all within a tiny square box with the vibrator lasting years and meanwhile I was working on a radio from a 52 Ford Meteor with a 6AQ5. The wiring within the vibrator was brittle and crisp from the heat as was the sponge.
