Home › Forums › Electronics Restoration › Torroidal Isolation transformer?
- This topic has 3 replies, 1 voice, and was last updated 17 years, 1 month ago by
February 16, 2008 at 4:45 am #894
Forum ParticipantI picked up a big torroidal transformer from a free pile at work. I didn’t know much about it but picked it up thinking it might be of use. it is quite heavy and around 3 inches thick and 8 inshes across.
I can’t find the exact model number or schematic , but their website is here: https://www.plitron.com/
My first question is if this thing has a chance of being usable as an isolation transformer for my bench. It is quite large , but I figured so what? if it works ok I assume I could limit the output with a 2 amp or so fuse…
I am guessing that the first two sets of leads are the primary. and that it has a dual primary. Beyond that I am unsure of a few things. It has lots of leads so it must have a range of input and output power levels.
why two primaries? is there an advantage to using both? can I use one? designed to use both sides of the power grid?
If I can figure out how to hook up the primary winding(s) to an outlet I could just measure the output . perhaps the multiple outputs could be rectified and filtered to use to power battery sets as well? I haven’t begun to see which leads are paired up , but I should be able to figure out which leads are paired up and what the resistance is. I am not sure if I can expect the wire colors to follow a particular convention , but I assume there may be some meaning to the colors.
Here is what is on the label:
106x1035R2 #1442 VA:2106 F:50
INPUT: 2 x (0-104 – 110 – 120 VAC )Here is how the wires are paired up :
4 bundles of wires
The first two have shrink wrapped ends:
brown-orange-black-red
blue-green-yellow-violetThen three separate wires (heavier guage)
Vilolet- white- blackThen two more wires grey, blue
Then three more red-yellow- green
I would appreciate any info anyone can give me on this. , and as an aside note, have a look at the chassis they have using tubes and torroidal transformers. , it’s here:
https://www.plitron.com/audio_gallery.aspFebruary 20, 2008 at 7:18 am #898HolderAccount
Forum ParticipantHere are some pictures of this transformer.
PhilDownload torroidal_1.gif. (Caution: This file may not be virus scanned.)
Download torroidal_2.gif. (Caution: This file may not be virus scanned.)
Download torroidal_3.gif. (Caution: This file may not be virus scanned.)
September 8, 2009 at 2:23 pm #1466Anonymous
InactiveHi Phil,
I have the wiring colour codes and datasheet for this torroid if you still need them, it was used on the old OEM LPE way back when I started with Creo….it was specially made for us by Plitron.
Dave BarrettSeptember 11, 2009 at 11:05 pm #1467HolderAccount
Forum ParticipantThank you Dave. I had given up on finding specific data and now I have a spec sheet with all the info I could ask for and it looks like it will be quite useful now.
