Home › Forums › Electronics Restoration › Tapped volume control problem/question
  • #2300
    Hello all. I’m a new CVRS member, although I’ve been collecting and restoring for over 20 years. I’m looking forward to enjoying the CVRS site and especially the forum.
    I’d like to ask a question about my RCA T5-2. It uses a tapped volume control. Two taps, in fact. It went bad, and the unit I installed as a replacement is not correct. I know that, because with the volume control at minimum, the radio plays at room level (i.e., can’t be turned lower than that).
    I ordered the schematic, but it is almost impossible to read. See the attached portion of the schematic (below) to see what I mean. Can anyone tell me what the correct resistances are (total and at each tap, measured from the ground end), or something close to what they ought to be?
    Thanks!
    Tom
    #2301
    I have a better schematic from an RCA manual and see only one tap. The large blurred line is not a tap but printing that says R-9, 250,000 ohms, total. I could email the schematic but you need to PM me your email address to do so.
