Home › Forums › Electronics Restoration › Rogers 12-91 or 8R931
- This topic has 11 replies, 1 voice, and was last updated 15 years, 7 months ago by
March 29, 2011 at 1:25 am #2322
InactiveLooking for some information on this radio. I cannot seem to find a diagram for this radio in all of my paper work. It seems to be a bit
different then others I have. This radio seems to have a regulator tube in it. Would any one know what this tube is and how I could find one
or if there is a way around this. It almost looks like a small lite bulb but glows very orange when on.
This radio also has a export number of 793R1 so am wondering if this is an export model.
Any information on this radio would help.
Mike
March 29, 2011 at 5:15 pm #2324
Ed KrausharCVRS MemberHi,
I have attached a schematic for your radio at–
https://www.nexicom.net/~oidar/rogersb510.pdf
Unfortunately the schematic is poor due to the very poor quality of the original schematic in the Rogers manual.
Check the chassis layout and parts list your bulb may be used as a fuse, one is indicated.
The tubes are Rogers Spray Shielded types and I would keep them if the radio plays with them as they can be quite rare. The waxed paper tubular capacitors along with electrolytic capacitor should be replaced before using the radio.
March 29, 2011 at 5:31 pm #2325Anonymous
InactiveEd
Thanks for the post. The diagram you have does not seem to be the model I have. The radio is a 1937-38 vintage and would have 2 2×3 tubes
and the newer spray tubes. In the circuit there is a regulator tube model number is 14156. It is also used in the 12-96 model. This model is
close but not the same as the 12-91 I have and connot seem to find this diagram anywhere. .Mike
Download IMG_new.JPG. (Caution: This file may not be virus scanned.)
March 29, 2011 at 8:20 pm #2327
Sorry about the confusion but I had a seniors moment and posted to the wrong thread.
I saw your post earlier and checked my Rogers manuals but could not find your radio. There is a 12-95 or 7R931 but your numbers do not show up. The 12-95 has two 6K7M, 6A7M, 86M, 6X6, 6F6, 6F5 and two 2X3 tubes. What are the tubes used in your radio? Perhaps with that I could search further.
There is something odd as an "8R" chassis number would have been issued a year later then the "12-91" model number. An "8R" chassis would have a 13/** model number.
March 29, 2011 at 9:47 pm #2329Anonymous
InactiveEd
Im having a issue as well LOL . This is a strange one for sure it seems to have all the same tube line up as a 12-95 but number for another chasis.
I added photos of the white stamp model and chasiss as well. The main issue I have is with the regulator tube in this model is missing but seems to work
without it. I believe this may have been added in yester years because of hydro issues.Let me know what you think.
Just a side note I have 2 of this models and have same numbers on both.
Mike
Download IMG_new1.JPG. (Caution: This file may not be virus scanned.)
Download IMG_new2.JPG. (Caution: This file may not be virus scanned.)
March 30, 2011 at 12:19 am #2332
I went back into a parts list in the Rogers manual, it lists your part #14156 as a bulb, neon lamp. No other explantion or specs.
I am at a loss for the purpose of it. wonder what would happen if a neon bulb with a suitable base was installed?
March 30, 2011 at 12:27 am #2333Anonymous
InactiveED
Thanks for the info again. Im not sure of its use but am looking into it but if someone else may know in the group we may find something new out.
Mike
March 30, 2011 at 10:47 pm #2334Anonymous
InactiveCan any one confirm that a zener diode could do the same thing. If so what might be the type of use for this radio.
It seems to have the same tube layout as the 11-95
Mike
April 5, 2011 at 11:23 am #2338HolderAccount
Forum ParticipantThe 12-91X is a New Zealand export model. It’s the same chassis as the 7R931 on page 23 of the Rogers manual. I just bought one of these in Angus 2 weeks ago. I haven’t attempted any work on mine yet, but I also have that regulator tube. My 6X6 still lights up somewhat but was wondering if anyone knew of a replacement?
Paul
April 5, 2011 at 11:54 am #2339HolderAccount
Forum ParticipantMike,
I do believe it’s the same layout as the 11-95. Here’s mine:
https://www.flickr.com/photos/pvkantique … 565349085/
Tube Layout chart:
https://www.flickr.com/photos/pvkantique … otostream/
Paul
April 6, 2011 at 4:34 pm #2341
mr-moeForum ParticipantPaulie I have a couple of the 6X6 if you need one.
Also have the settings to test on Jackson 648 tester.April 6, 2011 at 9:19 pm #2342HolderAccount
Forum ParticipantThat would be great Moe. I have two or three that I’ve picked up in tube lots but they always tested bad (no green).
Paulie
