Home › Forums › Electronics Restoration › Potentiometer Question
  • #24223
    • I’m working on a Rogers Majestic R221 and I’m puzzled by the volume control.
    • I suspect the switch portion is broken because when the radio is on and working if I turn the knob counterclockwise to turn the radio off the knob continues past the normal stop point.
    • I haven’t opened the unit up to physically inspect it.
    • It’s a type of potentiometer I’ve not worked on before because it appears to have two wipers if I’m reading the schematic properly.
    So my main question is what do I specify when ordering a new potentiometer with a switch.
    In the attached photo the white arrow shows the location of the second wiper.
    I’ve also attached a section of the schematic
    #24227
    Les,
    I have always found that type of connection shown on a drawing has always been a tap off of the resistive element not a wiper.
    I believe that it is used for equalization purposes on the audio.
    Good luck.
    #24228
    Hello Lee
    I have seen one of those Volume Control/ Switches with what seemed to be a second wiper. But I never pulled it apart to examine how it worked internally; You could pull it apart. What do you have to lose?? It is already broken as to the switch itself! I had a similar problem with a Cdn. Westinghouse volume control/switch. I pulled it apart but could not fix the switch. So I simply disconnected the leads to the switch and hooked up a tempory On/Off toggle switch until I find another/proper Volume/On/Off switch. The problem with taking the switch assembly apart , is that you must drill out the rivets (usually two). You may get lucky and find that it is just a bent stop caused by someone using brute force. If that is the case all you may need to do is just re-straighten it. However in reassembling it you may not be able to use screws to put it back together. As I said, It is already broken! Nothing to lose!
