Home › Forums › Electronics Restoration › Common/Chassis ground
  • This topic has 2 replies, 1 voice, and was last updated 18 years ago by Anonymous.
  • #1150
    Inactive
    I am replacing the elect. caps in a RCA Victor Q109 and I’m having problems determining where I should connect the negative of those elect. capacitors. I’m assuming that the negative of the present elect. caps are inside of the metal container since I can’t see any evidence of negative wiring outside of the can. Could the negatives of the new, individual caps be connected to any pin that goes to ground as per the schematic? I would appreciate any help in this matter,
    regards
    #1151
    the schematic is on Nostalgiaair, lots of info on this one.
    https://www.nostalgiaair.org/Resources/604/M0015604.htm
    there is a 4 section electrolytic C44A, C44B, C44C ,and ,C44D
    3 sections are 10 microfarads @ 450 Volts ( A, B and C )
    1 section is 20 microfarads @ 25 Volts (D)
    on the schematic each is referenced to ground. I assume this is the chassis. check if there is a fiber washer insulating the capacitor from the chassis. if the can is connected to the chassis I think you can follow suit by hooking the negative to chassis ground. If there is an insulating washer under the nut for the multi section cap it is there for a reason.
    unless you are restuffing the capacitor can you can just cut the positive leads and leave the old one in place for aesthetics. even if you do try to put the new caps inside the can it might be hard to fit all 4 in there.
    Check your work and bear in mind I am not an experienced bench technician
    #1152
    Inactive
    Thanks—–I have replaced the elect. caps and used the original can for ground…..works o.k.
