Home › Forums › Electronics Restoration › B Battery Eliminator
- This topic has 14 replies, 6 voices, and was last updated 3 years, 8 months ago by
Joseph Skrypka.
February 6, 2021 at 11:28 am #16204
Joseph Skrypka
Forum ParticipantHi all!
Does anyone have a schematic for a simple B Battery eliminator? I have a couple of old battery powered radios to restore and would like to eliminate the need for batteries.
Thanks!
JoeFebruary 6, 2021 at 1:37 pm #16208
garykusterForum ParticipantI don’t have a schematic, but this transformer would be a good start. perhaps it can be found cheaper.
February 6, 2021 at 4:29 pm #16216Bruce Morgenstern
CVRS MemberHi Joseph
I have attached a JPG schematic of a simple B+ power supply.
Hope this helps.
Enjoy
BruceAttachments:
February 6, 2021 at 4:36 pm #16218Bruce Morgenstern
CVRS MemberHi Joseph and others.
I have attached a 81 page PDF of connection diagrams for connecting vintage battery radios, it is used with a ARBE-III universal Battery Eliminator which I use.
Enjoy Bruce
February 7, 2021 at 6:54 am #16222Jean Marcotte
CVRS MemberWhen using Bruce’s simple schematic, use a polarized plug with B- wired to the neutral side to avoid a live chassis.
February 7, 2021 at 11:48 am #16224Bruce Morgenstern
CVRS MemberHi All
I just wanted to clarify, the schematic I posted was from the internet. I did not intend to take credit for it. I tried numerous times to upload the website with it on but to no avail. The schematic came form;
Phil’s Old Radios: Home: Building
BruceFebruary 7, 2021 at 3:35 pm #16225
John GreenlandCVRS MemberJoseph,
I have attached a very simple and inexpensive possible solution to your battery eliminator issue for the higher voltage. A couple of “D” cells will probably do for the filaments.
It requires 3 HP printer power supplies. I have found numerous type and power ratings at a local thrift store for 3 to 4 dollars ( Canadian) each.
They have 2 output voltages, 32 volts and 16 volts.
You need the ones with a 2 wire line cord. The three wire ones have the 0 volt wire (A) connected to the AC ground pin on the supply.If you wire them as shown they will give you your high voltage. The diodes are optional and will lower your voltage slightly.
I have used 4 of them in series (without the diodes) to power a 40 watt incandescent light bulb as a test without a problemRegards ,
John G.
VO1 CATAttachments:
February 10, 2021 at 4:37 pm #16235
Grant SesakCVRS MemberFebruary 14, 2021 at 3:27 am #16254Joseph Skrypka
Forum ParticipantThanks to all. For some reason, I’m not being notified of my messages, so I have not checked the site since last weekend.
I’ll work through all of the responses today!
JoeFebruary 23, 2023 at 11:30 am #16206Bruce Morgenstern
CVRS MemberHi Joe
Following is a link to a site that has a simple schematic for a very simple B+ power supply.
https://www.antiqueradio.org/bsupply.htmI have and use an ARBE-III Universal Battery Eliminator which is really handy and easy to use on old battery radios. Can’t say enough for it. There is an 81 page manual with wiring diagrams for hooking it up. Following is a link to the Battery Eliminator and I have also attached a PDF of the wiring diagrams.
Battery Eliminator:
https://www.arbeiii.com/Hope this might help.
BruceAttachments:
February 23, 2023 at 11:31 am #16209Bruce Morgenstern
Following is a link to a site that has a very simple B+ schematic that might help.
https://www.antiqueradio.org/bsupply.htmI use an ARBEIII universal Battery Eliminator that works on any of the battery radios I have come across and find that it is really works great. There is also a 81 page set of wiring diagrams which show all the hook ups for numerous battery radios. I tried to attach the PDF but the site would not accept it. Following is a link were one can obtain it.
http://arbeiii.com/ARBE-III%20Compiled%20Wiring%20Diagrams.pdfI hope this helps.
Bruce
February 23, 2023 at 11:31 am #16210Bruce Morgenstern
Following is a link to a site that has a simple B+ power supply schematic, just scroll down and you will see it.
https://www.antiqueradio.org/bsupply.htmI use an ARBEIII Universal Battery Eliminator for my battery radios which works really great. It is really easy to use and simple to hook up. There is also a 81 page set of connection diagrams for the early battery radios. Following is the site for the eliminator. I have also attached the PDF file containing the connection diagrams.
https://www.arbeiii.com/Hope this helps you.
Bruce
February 23, 2023 at 11:31 am #16212Bruce Morgenstern
https://www.arbeiii.com/Following is the link for the 81 page connections diagrams.
http://arbeiii.com/ARBE-III%20Compiled%20Wiring%20Diagrams.pdfHope this helps you.
Bruce
February 23, 2023 at 11:31 am #16213Bruce Morgenstern
I have also attached a PDF for the wiring diagrams
BruceBruce
February 23, 2023 at 11:32 am #16215Bruce Morgenstern
I have also attached a link for the wiring diagrams
BruceBruce
